The "Lavatory Floor" visual crashes the player in an infinite loop until "player -i" is entered at the serial port. BIG problem. The release notes suggest that this is a known issue, but also that this visual wasn't supposed to be present in alpha8 -- it is present.
Also, on Mk2a with 32MB, the long buffering from disk at the start of each track causes the UI to become completely non-responsive until the buffering from disk has completed. Some voluntary scheduling points in the code could fix this -- I may hack it into the syscalls within Hijack if need be.
Edited by mlord (14/07/2004 20:24)
