Hi All,
Just picked up my Central, and noticed that the standby button on the front panel doesn't work. If I use the remote, then I can put the unit into standby.
I'm running the 1.10 rc1 software.
I've opened the Central, and examined the PCB containing the buttons and all appears to be in order. I've tested the buttons with my multimeter, and they all work (even the standby one). I've also traced the standby connection to the connector and through the cable. It all looks good.
Does anyone know what other possible issues might cause this failure to go into standby when the button is pressed.
Thanks,
Andy.
