Or maybe it's me. Whatever the case, I don't know the first thing about debugging Java installs, so am at a loss.
I have running now: Ampache, ssdp.pl, NFS, DHCP, but I have not been able to get trio to run.
Gentoo easily installed sun java 1.4.2_10 but with that I get:
bill ~ # tail /var/log/trio.log
STARTED tRio Mon Jul 3 03:05:00 CDT 2006
Error occurred during initialization of VM
java/lang/NoClassDefFoundError: java/lang/Object
With great trouble, I found 1.4.2_06 but it did not make things better; I got the same error in trio.log but if I tried to run java from command line I got an error similar to what's in the trio.log.
I tried blackdown 1.4.2.03 but did not have success.
I've tried the JREs and the SDKs.
I suspect It's not the java version at all but some subtle (or not) configuration issue. Here's more information from my system:
bill ~ # /usr/local/trio/bin/trio.sh check
Hello ...
Defaulting TRIO_HOME to /usr/local/trio
RunCommand = /opt/sun-jdk-1.4.2.10/bin/java -Djava.net.preferIPv4Stack=true -Dtrio.home=/usr/local/trio -Xbootclasspath:/usr/local/trio/lib/pja-mod.jar:/opt/sun-jdk-1.4.2.10/lib/rt.jar -Dawt.toolkit=com.eteks.awt.PJAToolkit -Djava.awt.graphicsenv=com.eteks.java2d.PJAGraphicsEnvironment -Djava.awt.fonts=/opt/sun-jdk-1.4.2.10/lib/fonts -Djava.util.logging.config.file=/usr/local/trio/linux-logging.properties -cp /usr/local/trio/lib/commons-beanutils.jar:/usr/local/trio/lib/commons-collections.jar:/usr/local/trio/lib/commons-digester.jar:/usr/local/trio/lib/commons-lang.jar:/usr/local/trio/lib/commons-logging.jar:/usr/local/trio/lib/jrclient.jar:/usr/local/trio/lib/jrcommon.jar:/usr/local/trio/lib/jrutil.jar:/usr/local/trio/lib/trio-0.1.6.jar:/usr/local/trio/lib/trio-applet-0.1.6.jar:/usr/local/trio/lib/xmlrpc.jar:/opt/sun-jdk-1.4.2.10/lib/tools.jar trio.TRioServer -c/usr/local/trio/trio.xml
Checking arguments to tRio:
TRIO_HOME = /usr/local/trio
TRIO_CONF = /usr/local/trio/trio.xml
TRIO_RUN = /var/run
TRIO_PID = /var/run/trio.pid
TRIO_CONSOLE = /var/log/trio.log
JAVA_HOME = /opt/sun-jdk-1.4.2.10
JAVA_OPTIONS = -Djava.net.preferIPv4Stack=true -Dtrio.home=/usr/local/trio -Xbootclasspath:/usr/local/trio/lib/pja-mod.jar:/opt/sun-jdk-1.4.2.10/lib/rt.jar -Dawt.toolkit=com.eteks.awt.PJAToolkit -Djava.awt.graphicsenv=com.eteks.java2d.PJAGraphicsEnvironment -Djava.awt.fonts=/opt/sun-jdk-1.4.2.10/lib/fonts -Djava.util.logging.config.file=/usr/local/trio/linux-logging.properties
JAVA = /opt/sun-jdk-1.4.2.10/bin/java
JAVA VERSION =
CLASSPATH = /usr/local/trio/lib/commons-beanutils.jar:/usr/local/trio/lib/commons-collections.jar:/usr/local/trio/lib/commons-digester.jar:/usr/local/trio/lib/commons-lang.jar:/usr/local/trio/lib/commons-logging.jar:/usr/local/trio/lib/jrclient.jar:/usr/local/trio/lib/jrcommon.jar:/usr/local/trio/lib/jrutil.jar:/usr/local/trio/lib/trio-0.1.6.jar:/usr/local/trio/lib/trio-applet-0.1.6.jar:/usr/local/trio/lib/xmlrpc.jar:/opt/sun-jdk-1.4.2.10/lib/tools.jar
RUN_CMD = /opt/sun-jdk-1.4.2.10/bin/java -Djava.net.preferIPv4Stack=true -Dtrio.home=/usr/local/trio -Xbootclasspath:/usr/local/trio/lib/pja-mod.jar:/opt/sun-jdk-1.4.2.10/lib/rt.jar -Dawt.toolkit=com.eteks.awt.PJAToolkit -Djava.awt.graphicsenv=com.eteks.java2d.PJAGraphicsEnvironment -Djava.awt.fonts=/opt/sun-jdk-1.4.2.10/lib/fonts -Djava.util.logging.config.file=/usr/local/trio/linux-logging.properties -cp /usr/local/trio/lib/commons-beanutils.jar:/usr/local/trio/lib/commons-collections.jar:/usr/local/trio/lib/commons-digester.jar:/usr/local/trio/lib/commons-lang.jar:/usr/local/trio/lib/commons-logging.jar:/usr/local/trio/lib/jrclient.jar:/usr/local/trio/lib/jrcommon.jar:/usr/local/trio/lib/jrutil.jar:/usr/local/trio/lib/trio-0.1.6.jar:/usr/local/trio/lib/trio-applet-0.1.6.jar:/usr/local/trio/lib/xmlrpc.jar:/opt/sun-jdk-1.4.2.10/lib/tools.jar trio.TRioServer -c/usr/local/trio/trio.xml
tRio running pid=13676
bill ~ # java -version
java version "1.4.2_10"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_10-b03)
Java HotSpot(TM) Client VM (build 1.4.2_10-b03, mixed mode)
bill ~ # which java
So, are there versions of java known to work or not work with trio?
Is there an alternative to trio (preferably NOT java-based) that is as well designed? Specifically, I rather hated the orignal firmware, in that if you picked out some music it stopped playing what was on and played the new selection (rather than just adding it to the playlist)... duh.
Would tRio 1.7 behave any better? Maybe I'll try that in the meantime.
Thanks in advance,
Adam
