#111219 - 16/08/2002 18:36
Re: Can no longer sync my empeg??? Help!
Loc: San Jose, CA
I also see the following text in the hyperterminal:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v286 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Sun Jul 28 13:09:50 EDT 2002
empeg-car player (hardware revision 9, serial number 10101933)
Command line: mem=16m
Memory: 15072k/16M available (928k code, 20k reserved, 360k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004200).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-230, ATA DISK drive
hdb: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:8
d
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg-preinit starting...
empeg-preinit complete
empeg init 0.8
Mounting proc
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
opening display...
opening font file...
cannot open font file
Vcb: 0x4086d000
Calvin
#111225 - 16/08/2002 19:36
[Re: eternalsun]
#111229 - 16/08/2002 19:50
Loc: San Jose, CA
Except... I have two disks.
There is nothing wrong with the player. No missing files. I can access drive0 and drive1 and look around freely. I can mount and unmount rw, ro. With hijack in I can ftp in and out. streaming is ok. Everything is ok, except sync from emplode.
Calvin
#111231 - 17/08/2002 00:33
ext2fs_check_if_mount: No such file or directory while determining whether [mount point or device] is mounted.
IIRC this error is normal, and due to fsck looking for which filesystems that are mounted in /etc/mtab, but the empeg doesn't have an /etc/mtab file...
#111232 - 17/08/2002 11:55
[Re: eternalsun]
Can you do an ls -l / so we can see if you've lost mount points?
M2a/ Smoke/60gb/Tuner!! Thanks Joe
M2a/ Blue10gb Thanks Ian!
#111234 - 19/08/2002 11:26
Loc: San Jose, CA
empeg:/empeg/bin# cd /
empeg:/# umount /drive0
empeg:/# umount /drive1
empeg:/# ls drive0
empeg:/# ls drive1
empeg:/# fsck drive0
Parallelizing fsck version 1.19 (13-Jul-2000)
empeg:/# mount
/dev/root on / type ext2 (ro)
none on /proc type proc (rw)
empeg:/# fsck /dev/hda4
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
/dev/hda4: clean, 4806/228352 files, 2488799/7304850 blocks
empeg:/# fsck /dev/hdc4
hdc4 is mounted.
/dev/hdc4: clean, 23839/228352 files, 2507951/7304850 blocks
empeg:/#
I rebooted, then tried to sync again, and it does not sync. It just reboots instantly when a sync is attempted. (!?)
Calvin
#111238 - 19/08/2002 13:36
Loc: San Jose, CA
It's actually now a different error than before. So it's failing at a different place.
The following is a more detailed manual fsck, as per the FAQ, but alas, with the same results. I don't really see an error, except for the "no such file or directory" thing, but I'm told that is normal? So if that's the case, there is theoretically nothing wrong but it will not sync. :-( The good news is I can still *listen* to music, I can still operate the hijack web server, the hijack ftp server, etc etc. Nothing else seems out of the ordinary.
empeg:/# ro
empeg:/# umount /dev/hda4
empeg:/# umount /dev/hdc4
empeg:/# swapon /swapfile
Adding Swap: 16596k swap-space (priority -1)
empeg:/# fsck -fay /
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1527/4096 files (0.5% non-contiguous), 9701/16384 blocks
empeg:/# fsck -fay /dev/hda4
hda4 is mounted.
/dev/hda4: 4806/228352 files (3.5% non-contiguous), 2488799/7304850 blocks
empeg:/# fsck -fay /dev/hdc4
hdc4 is mounted.
/dev/hdc4: 23845/228352 files (0.7% non-contiguous), 2507959/7304850 blocks
empeg:/# swapoff /swapfile
empeg:/# sync
Calvin
#111239 - 19/08/2002 14:14
[Re: eternalsun]
Loc: Louisiana, USA
Is there anything else he can try short of reformatting? Maybe a fresh install of emplode on a different computer?
Stu
#111242 - 19/08/2002 20:32
Perhaps not reformatting. Perhaps a fresh load of a standard upgrade would be enough. It would wipe the root partition, but leave the music intact. Question: are you syncing over ethernet, USB or (heaven forefend) serial?
#111243 - 19/08/2002 20:33
Loc: Los Angeles, CA
yeah, i was just about to say. i've encountered this problem when i ran a userland app that was on my music drive. if you kill -hup all the 3rd party, you should be able to sync.
