#172007 - 24/07/2003 06:31 More RDS-AF findings
tms13
Loc: Lochcarron and Edinburgh
Sorry I've been quiet for the past few weeks - holiday and work both eating my time.
During my travels, I think I've found why AF following wasn't working for me while I listen to MP3s. Try this:
  • Tune to BBC Radio 4 in Cambridge, ensuring that AF Debugger shows an active display
  • Drive north for a few hours
  • Note that before you reach Glasgow, the player struggles to find signal on any alternatives
  • Eventually, it will tune in to BBC Radio Scotland instead of Radio 4 (and it doesn't seem to check the PI, but that's already reported)
If, however, you re-tune somewhere near Penrith (by knocking the stalk forward then back, for instance), it works properly.
What I think is happening is that when we re-tune to a new station, we're not picking up a new AF list. So in a linear country, with transmitters A, B, C, ... where each one advertises its immediate neighbours, if we travel from B to C, we'll still only check A B and C, even though we should be sampling B C and D. Which means that when we lose sight of C we will be unable to find any decent signal.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#172008 - 24/07/2003 06:48 Re: More RDS-AF findings [Re: tms13]
Either that or it just sulks as you move away from it's spiritual home of Cambridge
#172009 - 28/07/2003 08:21 Re: More RDS-AF findings [Re: tms13]
boxer
Loc: Yorkshire UK
Strange you should mention that, outside Penrith on the A66, my tuner went from R2 to R3, then lost the radio altogether, when I pulled it out and re-started it, it found a perfectly good signal - must be the Penrith effect!
Similar thing happened in Cirencester, perfectly good signal on the way in, completely lost RDS when I left two days later, but that's with 3.0A.
#172010 - 28/07/2003 09:30 Re: More RDS-AF findings [Re: boxer]
tms13
3.0A? When did that appear? I didn't see anything on Announcements.
/me heads over to General to catch up on the last 4 weeks.
Toby Speight
#172011 - 28/07/2003 09:51 Re: More RDS-AF findings [Re: tms13]
Daria
You can't have it.
#172012 - 29/07/2003 01:34 Re: More RDS-AF findings [Re: tms13]
boxer
Loc: Yorkshire UK
Oops, sorry, broke cover, but I'm far from the first, you had to be at Amersfoort. But it doesn't help you much, tuner wise.
