My installation attempt went without a hitch, it helped that the old head unit wasn't that old so it was pretty much a wire for wire swap. I did use an adapter that was on the old head unit and it fit great on the Mk2 and I trimmed a little plastic on the dash opening on the left & right sides in order to pull the Empeg out of the sled (handle sides hit the sides of opening), it sets flush w/dash rather than sticking out. I had already installed a 300 watt amp recently to it so the install time was minimal. I used the old vehicle as a trial run before installing into the new car as soon as I get another sled. Installing in a Bronco II was probably too easy, theres plenty of room behind the dash, it's almost cavernous. I have the Blue faceplate that really appears blue-green, but that matches the dash lights even better.
#090000695 Mk2 BLUE 12Gig
