#223198 - 23/05/2003 16:47 Jukebox Mode
lockeness
The new 1.3 alpha is real nice. I am confused, though, what the difference between the Jukebox mode and the queue and play node is. Also, will 1.3 work with Jrec 1.5 that just was released?
#223199 - 23/05/2003 18:06 Re: Jukebox Mode [Re: lockeness]
djyoung
- The difference, according to Paul in the 1.3 Features list topic (look down a bit) is that in "Jukebox" mode, you simply pick one song and it will continue through your playlist from there, rather than Queue'n'Play, where you queue up the music to play (ie, it's all in how you pick it)
- I'm assuming you mean JRec 2.5, and to that I'd say yes...That's exactly the setup I'm running, and apart from some Java Font complications that I believe are unrelated (I get them even if JRec is not running), I'm going fine.
