#224870 - 30/05/2004 00:25 Can't restore as new
I found my recovery cd but I still get an error. When I put the disk in it comes up apply upgrade. I choose that then it says restore to "as new" or upgrade now. I choose restore as new and get the warning. I choose restore to "as new" and I get the error :
There was an error applying the upgrade (status 0xc0044000) CD may be damaged or incorrectly written.
I can still read audio cd so I would think the cd-rom is working ok ?
Any ideas ?
Edited by msaeger (30/05/2004 00:27)
#224871 - 30/05/2004 21:02 Re: Can't restore as new [Re: msaeger]
geeknerd
Will it let you "upgrade"? I believe "restore as new" will wipe all your music.
#224872 - 30/05/2004 21:16 Re: Can't restore as new [Re: geeknerd]
Nope I get the same error with the upgrade. The cd says it has 1.02 on it.
#224873 - 01/06/2004 08:03 Re: Can't restore as new [Re: msaeger]
robricc
I can make an image of the original disc if you want.
#224874 - 01/06/2004 08:06 Re: Can't restore as new [Re: robricc]
I was using the original disk that came with my central. It has 1.02 on it what version does your disk have ?
#224875 - 01/06/2004 08:11 Re: Can't restore as new [Re: msaeger]
robricc
I don't know. It doesn't say on the disc. I would assume it's the same.
I was figuring you might want it if your disc is damaged.
