#231270 - 22/08/2004 18:58 v0.1.5 browser issue
bha
Under IE6 w JRE 1.4.2_04 the web screen works fine.
On my linux box, running KDE, Konqueror 3.2.2, JRE 1.4.2_03 I notice 2 problems. 1) About half the time the screen does not paint correctly with a jumble of stuff in the upper left corner of the browser window. A refresh fixes this. 2) When it does paint correctly the bottom of the panel is below the window so you must scroll down a little to get to things like Power Off, Reboot, or Standby. There is a band of white space above the panel about the size that the bottom is cut off (i.e. the grey panel is the correct size to match the window, but is sitting a little down in the window). I could provide screen shots if necessary.
Do you want bug reports here? On the Sourceforge site?
Bryan: tRio 0.1.5, Jreceiver 0.2.5 running Debian Sarge AMD-K6 300mhz 128mb mem, only 5k mp3s using 15gb, 2 Dell, 2 rebadged SonicBlue DARs
#231271 - 23/08/2004 05:53 Re: v0.1.5 browser issue [Re: bha]
pauln
I've only tested this under IE and so Konqueror is uncharted territory.
1. Please write this up on sourceforge: http://sourceforge.net/tracker/?group_id=72920&atid=536118 . Looks like I'm going to have to attach a monitor to my "under-stair cupboard" machine to debug this one.
2. If you know anything about html, try adjusting the settings in docs/trio-applet.htm. It may need alignment or border tweaking.
Paul
