#240662 - 08/11/2004 17:30 tRio wont fire up - first time install
tbguk
Here's the skinny - I have jre150 (which works fine with Azureus). I install tRio as per the instructions. All I get is this :
C:\Program Files\tRio-0.1.5_01>java -X"bootclasspath:c:\Program Files\tRio-0.1.5
_01\lib\pja-mod.jar;C:\Program Files\Java\jre1.5.0\lib\rt.jar;C:\Program Files\J
ava\jre1.5.0\lib\jsse.jar" -Dawt.toolkit=com.eteks.awt.PJAToolkit -Djava.class.p
ath="C:\Program Files\Java\jre1.5.0\lib\tools.jar;c:\Program Files\tRio-0.1.5_01
\lib\trio-0.1.5.jar;c:\Program Files\tRio-0.1.5_01\lib\commons-logging.jar;c:\Pr
ogram Files\tRio-0.1.5_01\lib\commons-beanutils.jar;c:\Program Files\tRio-0.1.5_
01\lib\commons-collections.jar;c:\Program Files\tRio-0.1.5_01\lib\commons-digest
er.jar;c:\Program Files\tRio-0.1.5_01\lib\commons-lang.jar;c:\Program Files\tRio
-0.1.5_01\lib\jrcommon.jar;c:\Program Files\tRio-0.1.5_01\lib\jrutil.jar;c:\Prog
ram Files\tRio-0.1.5_01\lib\jrclient.jar;c:\Program Files\tRio-0.1.5_01\lib\xmlr
pc.jar" -Djava.util.logging.config.file="c:\Program Files\tRio-0.1.5_01/logging.
properties" -Dtrio.home="c:\Program Files\tRio-0.1.5_01" trio.TRioServer "-cc:\P
rogram Files\tRio-0.1.5_01\trio.xml"
Exception in thread "Thread-10" java.lang.AbstractMethodError: com.eteks.awt.PJA
FramePeer.isRestackSupported()Z
at java.awt.Component.addNotify(Unknown Source)
at java.awt.Container.addNotify(Unknown Source)
at javax.swing.JComponent.addNotify(Unknown Source)
at javax.swing.JRootPane.addNotify(Unknown Source)
at java.awt.Window.addNotify(Unknown Source)
at java.awt.Frame.addNotify(Unknown Source)
at java.awt.Window.pack(Unknown Source)
at trio.gui.TRioFrame.pack(Unknown Source)
at trio.clock.TRioClockFrame.init(Unknown Source)
at trio.clock.TRioClockFrame.<init>(Unknown Source)
at trio.clock.TRioClockApp.unitConnected(Unknown Source)
at trio.TRioUnit.notifyConnectionListeners(Unknown Source)
at trio.TRioUnit.setConnectionStatus(Unknown Source)
at trio.TRioUnitControlThread.run(Unknown Source)
Any ideas ?
#240663 - 09/11/2004 06:55 Re: tRio wont fire up - first time install [Re: tbguk]
pauln
tRio uses a clever bit of software called PJA (see http://www.eteks.com/pja/en/ ) to do its screen rendering. Apparently PJA needs some changes to work with java 1.5 (see http://www.eteks.com/pja/en/forum/viewSubject.jsp?subjectId=481 ).
And so I'm afraid that until then, we're suck with java 1.4.2. I know that the install instructions say 1.4.2 or later - sorry.
Paul
#240664 - 09/11/2004 13:18 Re: tRio wont fire up - first time install [Re: pauln]
tbguk
That did the trick - thanks !
