#246570 - 15/01/2005 12:58 Printer not printing right away...
burdell1
I have an Epson R300 printer and when I try to print something it doesn't print out right away. It is only after I shut off my computer and restart it, it will print. If I remember correctly, it started doing this after I updated the driver. Any ideas on what might be causing it?
#246571 - 15/01/2005 13:18 Re: Printer not printing right away... [Re: burdell1]
The driver???? Just kidding...
Check to see if you have turned on any spooling or caching options on your printer settings. It sounds like it is printing to a spool, and when the computer is reset it sees items in the spool and dumps them accordingly.
#246572 - 15/01/2005 13:31 Re: Printer not printing right away... [Re: pgrzelak]
burdell1
It is set to spool....what is the default setting for most printers?
#246573 - 15/01/2005 13:41 Re: Printer not printing right away... [Re: burdell1]
Mine is also set to spool, but also selected is to start printing immediately. This is under Windows XP.
#246574 - 16/01/2005 13:14 Re: Printer not printing right away... [Re: pgrzelak]
burdell1
I have mine set to print immediately too, but it doesn't.....I am not sure why though
