#3128 - 10/08/1999 18:45 bit rates
Coyote
I just was wondering, does the Empeg support variable bit rate encoded files?
I don't use Xing's encoder currently but am considering it due to the speed advantage. I just don't want to have to do it all over again. I am assuming that there should be no problem with 128 kbps files from the Blade encoder - if this is incorrect, *please* let me know.
#3129 - 11/08/1999 05:13 Re: bit rates [Re: Coyote]
Kram
I use variable bitrate files from AudioCatalyst on my Empeg unit with no problems.
Mark.
#3130 - 16/09/1999 17:44 Re: bit rates [Re: Coyote]
glessard
Whether you hear a difference is dependant on many factors. Some people can't hear the difference; this depends
on their appreciation of sound quality and/or where the weak element of their sound system. In my case, I do hear the
difference, and in the situations where I listen to mp3 I use either 160 kbps or AudioCatalyst's VBR (normal) mode.
That way, a saxophone actually *sounds* like a saxophone. Note that I don't think it's CD quality (it's much les), but it
seems like a reasonable compromise. On the other hand, some people think 112 kbps is enough.
