#315251 - 19/10/2008 06:50 Lock-switch in a Karma
StigOE
I decided to put a CF card in my Karma after reading the recent post about it here, along with a new battery. Various sites mention that it's easy to break the lock-swith, so I was careful when dismantling the player, but then forgot about it. When I was finished fiddling with the player because it was a bit difficult to get the adapter and card to fit, of course the switch was broken... Does anyone know where I can get a couple of new switches, as I use the Lock-button quite a lot?
Stig
#318026 - 12/01/2009 11:17 Re: Lock-switch in a Karma [Re: StigOE]
I believe a suitable switch can be found on digikey; you may need to take some measurements and look at the pictures in the catalog closely to make sure you get the right one.
Buy a couple because they break easily wink
#318084 - 13/01/2009 19:20 Re: Lock-switch in a Karma [Re: altman]
StigOE
Thanks, Hugo.
Do you know if they might be available from Farnell as well, as it's easier to order from Farnell than Digikey?
Stig
#318337 - 21/01/2009 03:47 Re: Lock-switch in a Karma [Re: StigOE]
Hmm, possibly. See part number 3931225.
The datasheet is not on farnell's site, but the manufacturer has it here: http://www.ck-components.com/14389/pcm_24mar.pdf
Worth checking the measurements and seeing if it'll fit. The two mounting lugs, side solder mount points and uneven 3 terminal spacing on the back look familiar - it's not the one that was actually used, but there are a lot of equivalents in the switch world....
edit: on the other hand, farnell appear to want to charge you 16 quid to send it...
Edited by altman (21/01/2009 03:49)
#318339 - 21/01/2009 09:19 Re: Lock-switch in a Karma [Re: altman]
StigOE
Thanks, Hugo.
That number was out of stock, but they had 9575146 as an equivalent and in stock. Here they charge £6 + VAT in shipping. I'll check the measurements and just add it to my next order from Farnell if it'll fit.
Stig
