#44108 - 29/10/2001 07:35 DHCP renewal fails
edwin
Loc: Druten, The Netherlands
The player gets an IP address from a DHCP server, then I unplug the network cable and let it sit for a while. It will try to send a renewal request, but since the cable is unplugged, it fails to do so. Details on the serial output are in the attachment. Is this neighbour table overflow error bad?
42998-dhcp_renewal_error.txt (139 downloads)
[white]ญญ______________[/white]
Edwin de Vaan aka FLaSHmAStER
#44109 - 29/10/2001 10:56 Re: DHCP renewal fails [Re: edwin]
Well, the neighbor table overflow seems to be linked to the loopback adapter starting after the regular eth0 adapter. I get around it (and avoid the error) by doing the following:
# ifconfig eth0 down
# ifconfig eth0 up
There are probably easier ways to do this (put it in init, profile, etc.), but I am lazy and in the habit of typing text commands. This should eliminate the neighbor table overflow errors.
