The top menu has "About" between "Off" and "Playlists" in 8a. I suggest you move the "About" futher away from "Playlists" and add a time out to "About."
So the default will hightlight "Playlist" when selected, and "Off" will be one selection to the left and "Source" continues to be one selection to the right. The two most commonly used options (after "playlist")would be easier to access. Thanks!
