If you've been following the other thread about HiJack v1.43 I've been having a problem with restore visuals! And Mark kept adding debug output to the serial port, it came down to the fact that my player thought it was in AM mode! Yet it wasn't. And mark kept coming up with ideas. You rock!
Mark suggested I press the "Source" button. I did and changed it to AUX then back to "Player"
I set it to a visual (Info: Off) and rebooted! And the VISUAL WAS RESTORED!!!!!!!!!! SWEET!!!!!!!!!!!!!!!!!!!!!!!!!!
Thank you SOOOO much Mark, you da the man. Keep up the good work!!!!!!!
For more information on my problem you can view the thread below at this starting point:
http://empeg.comms.net/php/showflat.php?Cat=&Board=hackers_prog&Number=60707&page=0&view=collapsed&sb=5&o=0&fpart=4&vc=1
My resolution to the problem:
http://empeg.comms.net/php/showflat.php?Cat=&Board=hackers_prog&Number=60707&page=0&view=collapsed&sb=5&o=0&fpart=8&vc=1
Edited by Fastrack (31/01/2002 07:59)
Ben Rio Car 10GB + 60GB Toshiba ([green]Green[/green]) - Serial # 30102833
