#85954 - 07/04/2002 16:33 emplode error when sync'ing and cleaning empeg
Anonymous
Unregistered
Got a few questions here.
When I add new music to the empeg and after it is done copying all the music it fails to restart the empeg successfully. I have to unplug and reboot. Its not a real big deal since everything gets copied OK. Thats when using USB. Have not got to try ethernet yet. Is there a fix for this? I'm using 2.0b11 emplode.
Also what is everyone else using to clean the display of the empeg?
-HeavyHit
#85955 - 07/04/2002 17:53 Re: emplode error when sync'ing and cleaning empeg [Re: ]
Known problem. FITNR. This is a "cosmetic" problem only -- your data has been successfully transferred, so you shouldn't lose too much sleep over it.
#85956 - 07/04/2002 17:53 Re: emplode error when sync'ing and cleaning empeg [Re: ]
Laura
Loc: Greenhills, Ohio
Failure to restart the player after a synch is a known bug and will be fixed in the next release. It helps to have the player in standby when starting a synch, it usually works right that way.
I use a very lightly damp paper towel to clean being very careful not to have it too wet. I'm not sure what chemicals would be safe if any like glass cleaners.
Laura
MKI #017/90
whatever
