#13020 - 07/08/2000 05:55 volume
jstrain
Loc: philadelphia pa
since i am running the empeg through my existing pioneer unit, what should i keep the empeg set at with regards to volume? or should i leave the pioneer set at a particular volume and adjust volume with the empeg? thoughts, concerns, witty sayings?
jeremy
oh, i wish i wish i had an empeg...
12 gig, green...
#13021 - 07/08/2000 10:57 Re: volume [Re: jstrain]
Since the Empeg is going into the Line Level input on the Pioneer, it should be set at 0db and you should use the Pioneer to adjust the volume. Assuming everything is hooked up properly, this should allow the Empeg to be at about the same volume as the Pioneer CD player and the Pioneer radio, as well as giving the best audio quality out of the Empeg.
#13022 - 07/08/2000 11:33 Re: volume [Re: tfabris]
alear
Loc: Montana, USA, Bozeman
Check the recommended input voltage for the pioneer head unit. If it is less than 4 volts peak-to-peak, adjust the empeg output accordingly.
Alex Lear
Alex Lear
#13023 - 07/08/2000 14:04 Re: volume [Re: jstrain]
BillB
Loc: Orlando, FL USA
One of my favorites I believe was a 'Deep Thought' by Jack Handy -
"People are like cows, but different."
[orange]Bill B.
Mk.2 SN 080000183 - 38 GB /[/orange] [green] Green [/green]
