#216377 - 17/05/2004 02:19 MKI upgrade to v.2.00
Vanity
Hello all
Yesterday, i tried to upgrade my MKI player to v2.00. I first upgraded with version v2.00 beta. After that i saw that there's v2.00 released and did again the upgrade. i installed the new emplode and changed from serial to usb. everything worked fine. i then went out took the player in the car and again no prob at all. As i came back and wanted to start again emplode (connected with usb), nothing worked. even tough the pc recognized new hardware, emplode couldn't find empeg player. I tried to connect via serial cable and the player has been found again.
I then uninstalled/reinstalled emplode but there was still the same problem. Connection via serial cable is doing well, but usb is not working anymore.
PC: Pentium IV, Windows 2000
Did anybody already had the same problem?
#216378 - 17/05/2004 08:22 Re: MKI upgrade to v.2.00 [Re: Vanity]
Did you upgrade emplode, too? It's not clear what version of the player software or emplode you had before, so if you were at 1.x, you need to upgrade both.
#216379 - 17/05/2004 08:35 Re: MKI upgrade to v.2.00 [Re: wfaulk]
You might also want to verify the USB drivers. When moving from the 1.x to the 2.0 versions, there was a USB driver change. You may need to load a new driver set into your PC.
