#224256 - 13/12/2003 21:28 java.lang.SecurityException w/trio 0.1.4.alpha5
dbrower
Quiet One
STOPPED Sat Dec 13 18:31:22 PST 2003
STARTED tRio Sat Dec 13 18:38:53 PST 2003
Exception in thread "main" java.lang.SecurityException: class "trio.TRioConfigur
able"'s signer information does not match signer information of other classes in
the same package
at java.lang.ClassLoader.checkCerts(ClassLoader.java:599)
at java.lang.ClassLoader.defineClass(ClassLoader.java:532)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:12
3)
This is on a linux machine, having extracted the jar files on Windows with winzip, and copied them to the linux machine using Samba.
I had earler run the trio on the windows machine, where it had fired up successfully. (Though it failed to actually play anything
against the original ARM server). I tried to move it to linux
to run against a JReceiver server, and it won't start. I suspect
something got corrupted in the copy to linux, but i don't know
how to extract a .zip file there -- gunzip seems not to do the job.
curiously,
-dB
#224257 - 14/12/2003 06:36 Re: java.lang.SecurityException w/trio 0.1.4.alpha5 [Re: dbrower]
pauln
Sorry, this is because I left a redundant file in the lib directory - this only seems to be a probloem under linux. Try removing Strio-applet-0.1.4.jar.
Paul
Paul (the tRio guy)
#224258 - 14/12/2003 13:51 Re: java.lang.SecurityException w/trio 0.1.4.alpha [Re: pauln]
dbrower
Quiet One
yup that got it. the next thing that bit was confusion that the -x11 option to the shell turned -off- use of the X11; one might have imagined it the other way.
thanks,
-dB
