#261814 - 28/07/2005 22:45 Narrow Faceplate?
jdk
By chance, has anyone created a narrow faceplate replacement?
My Empeg fits car one fine.
Car two, the factory radio is recessed, and a rubber faceplate covers it. :-|
Option 1: loose the portability of the Empeg, and mount behind the factory face plate. Not excited about that.
Option 2: Have the Empeg mount forward. Kind of looks out of place.
Option 3: Cut the factory rubber faceplate. No matter what,
it will look like it was cut to make the Empeg fit.
Option 4: Build a replacement factory faceplate out of mahogany, and make it look like current woodgrain interior car trim. Just more work than I want to deal with right now.
Other options?
Thanks.
#261815 - 01/08/2005 03:54 Re: Narrow Faceplate? [Re: jdk]
Not that's ever been posted on the board, and I wouldn't expect it to happen, either, unless you do it yourself -- the problem is that the handle attaches in that little bit of extra width, so if you make a narrow face plate, you lose the handle. The other problem with a narrow faceplace is that everyone's "narrow" is going to be slightly different, depending on the make of the car. Mine would have had a millimeter, or two in the back, and then be tapered to about twice that in the front.
