During the install of emplode, you are asked for the serial number of the unit. Although I am pretty much sure that this is non-functional, I'd just like to check if the serial number of the unit is placed on the unit at any time to match the physical label on the outside of the case. Is the number sent to the unit?
If so, is it accessable via any library API, or interrogation method of the player while it's running as a process?
One of the few remaining Mk1 owners...
One of the few remaining Mk1 owners... #00015
