Just put thru B12b. Yaaaay phone muting. Owww, it don't work proper like.
I had the phone mute set to +12V and it only worked when I momentarily put the unit to sleep (while starting the car) the unit then went into phone mute, track still playing in back ground. Only problem was, the phone wasn't ringing or otherwise working!
I am not actually sure whether the phone connection does work (homework for me!) but this does seem to be a problem.
I do love the way it only goes to sleep when the IGN is off. It starts up faster than my Radio! Only wish that it would just stay asleep for longer before shut down. perhaps an hour or two. any longer than that and you are probably too far away from your car and should have the Empeg with you!
Murray 06000047
____________________
