Ultimately, upgrades will happen via the standard protocol, so it can be done via serial, usb, or ethernet. If the unit is totally hosed, you'll have to use serial, but otherwise it can be done quicker and neater by USB or Ethernet.
There probably won't be a lot of changes to the upgrade procedure until that point, though.
Hugo
