Ok, bad or no reception from my tuner. Checked the FAQ and found "Some cars require that you apply power to a built-in antenna signal amplifier. The tuner module extension cable has a blue wire for this purpose. Check your wiring diagrams to locate the correct wire in your car's wiring for it.". Does anyone know if the factory Porsche antenna is one of these? ('96 993 with windshield antenna)
Bodybag - So Cal
Not a Whiner any more!!!
