That spot is the "getter" inside the vfd. When vfd's are made and the vacuum is drawn there is a little metal ring right under that spot called a "getter" that is energized and all the impurities are sucked to the spot so the rest of the display has a perfect vacuum. If you look at some old radio tubes they have the same thing and it looks the same.
Ben
mk2a 60gig green/Greenlights Buttons
mk2a 40gig blue no illumination....yet
hijacked
