You shouldn't need to combine the front/rear RCA's to one to go into the EQ... they should both have the same line output level and combining them will gain you nothing. Just connect the fronts and leave the rears off.
But, as was stated... why not just use the empegs EQ? Or is this so you can tune each speaker set seperately?
|| loren ||
