OK, it seens like all the individual visuals are working fine but here is the strange thing. If you select one visual it will work fine but if you select Auto Change, either On Track or Time Out, the visual will play till it needs to change to the next one the then goes to the RIO visual and stays there. I have tried just about very combo I can think os to make it work or not work and all end with the RIO visual on next change and it just stays there. When it freezes is when you select Random under the Select Mode section. Does this help you guys any.
