Do you think the box could be modded to take the output from the S/PDIF board ??? I could consider getting on of those boards then.
I am not certain if the regular outputs that S/PDIF uses would work. However, I remember Stu saying something about routing the signal out through the microphone in line, or another docking connector line. If that is the case, I would say that it could be modified.
The answer, of course, is to buy a second dock. Though with the current queue, I think you might be waiting until *next* winter.
What makes you think I haven't already?
I ordered them all at the same time, but asked Mark to delay the additional ones until others had a shot at their first dock. The others are in queue, and will be sent when they are done.
