Yeah but it looks like such drivers don't exist. Also it seems that things are running in PIO mode only with the drivers I do have since it really runs the P3 1GHz into the ground when using the drive.
Apparently also Dell don't support drives on the Serverworks IDE channels - only tape drives and CDROMs
![](/images/icons/tongue.gif)
. They want SCSI only.
So I'm going to get a Promise ATA card which
apparently has NT4 drivers and
apparently supports LBA48
But your RioCar/Empeg (with Hijack) will access the full capacity just fine.
Of course thanks to you. And it's quite a simple change as I understand it from reading the ATA specs. Aaah the wonders of open source...
