You could also probably do what I do with the empeg to make file transfers. Set your computer to show the file type extensions, then just rename the extension to ".mp3". Then I just use emplode to load the file on like an mp3. It works great. You just have to make sure you rename the extension back to what it was when you download the file back from the empeg. If you are doing this with several different types of file extensions and want to make sure you remember the right type for each file, you can include the type in the filename. For example, if i had a file called "filename.exe" I would rename this file to be called "filenameexe.mp3" Then when I downloaded this back onto a computer, all I would have to do is delete the mp3 and move the period in front of the "exe". My guess is that you could use this method to turn any mp3 player into a file transfer device although I dont know for sure.
