You should be able to just get your fingers on both sides of the top edge and gently pull the display towards the bottom of the case.
I tried that (twice, now) and the display doesn't move. I have pressed hard enough to cause mild discomfort on the balls of my fingertips, and am afraid to press harder than that.
I would guess the bottom edge of the glass is 3--5 mm above the metal lip on the bottom of the front of the case.
What holds that display glass in place? I remember reading somewhere something about sticky pads...
The VFD mounting height is adjustable during manufacture - it depends where the sticky pads that hold the glass to the PCB are placed, as the glass itself has pins coming out of one side only.
(boy, am I good, or what! :-)
...but I don't really understand the construction of it.
