I've not tracked it down but I think it's a bug in Hijack somewhere. Mark thinks it's userland and I think it's the kernel
I followed the example code that Mark put in the header file to show how to bind to the menu. The only change was that I didn't do the setgeometry call as it bitches if you try to use the values for full screen. The source code for empacman and emptris are both available anyway.
I'll have a better look at it tommorow anyway. If it's a problem with my code then I apologise now for pointing the finger at Mark and his changes.
If it was just with the stuff I'd written then I'd agree that it was probably me but it happens with everything that binds into the menu from what I can tell. *shrug*
- Trevor
