Hijack has a left/right timeshift setting. It is set in cm or milliseconds. I am not exactly sure how to properly configure this. Is the distance supposed to be the offset from the driver's ear to dead-center or do I need to triangulate my listening position or...? Also, it's not clear to me which side you're delaying. For example, if I set the shift to the right for ~67 cm / 2.0 ms, does that mean the right speakers transmit their audio 2.0 ms sooner than the left speakers? Any light shed on this subject would be appreciated. I think the purpose of this feature -- in the case of left-hand (U.S.) driving cars for example -- is to "slow down" the sound from the left side so that it reaches your ears at the same time as the farther-away sound from the right side. Thanks.
[yellow]
________________
Grant Eaton
ProtonVehiCROSS
[/yellow]
