I have been searching around the board and have seen many threads addressing lots of different empacman issues.
For one, I am worried about installing it and having it bind to my hijack menu.
Does anyone know if adding empacman will cause problems? Is there a faq anywhere with suggestions of where to store it on your empeg drives and a step by step install process? I would be curious where to put it so that it isn't effected by upgrades and the like. I am also considering adding the ;@EXEC_ONCE /drive0/var/empacman/empacman string into my ini file but then I saw someone say that doing that can use up your players resources. Is that true??
Could anyone suggest the best way to install empacman with doing the least amount of damage to empeg resources???
