It is very simple. There are three connections on a standard 1/8" stereo headphone plug. The ring (contact nearest the wire) is GND, the tip is SIGNAL and the middle contact is SHIFT. Shift is just a switch to GND which closes when you push in on the seek ring (don't know what else to call it). Signal is just a resistor to GND. The resistance depends on which button you're pressing. No buttons pressed is infinite resistance. The values are:
Resistance | Button |
0 | OFF |
2.2k | SOURCE |
4.4k | MUTE |
6.6k | LIST(DISP) |
8.8k | SEEK DOWN |
12.1k | SEEK UP |
16.8k | VOLUME DOWN |
23.6k | VOLUME UP |
33.6k | SELECT |
48.6k | MODE |
(up/down assume stick is pointing to the right)
There are no active components in the stick, it's just switches and resistors.
