1) Hmm .. really? I thought I set the data type to Integer. crap.
2) We're much closer to this in the unreleased version ... Actually if you notice, soup playlists don't have any properties set except title. To support some UI features of RMM for the Karma I had to add in support for copying the other properties over too -- so now soups actually have values for artist, album, year, etc (they take the value of the first entry that causes the soup to be made, so if you have an album that has tunes with different years in them, the first one is the one that gets displayed on the soup). So the second part is still not quite there, which is autosorting a soup by a field other than title ... This is coming. I've been slowly working this into the API's, but it's just a bit of a cancerous change because soups are kind of complicated and built on a lot of more generic things (for instance, soups are built on the generic concept of a container, which currently doesn't have the concept of sorting on "tags" -- it seemed OK to require that things have names, but requiring them to have arbitrary sets of properties seemed dirty ... i sort of bit the bullet and put it in anyway for now).
ms
