Well folks,
I've been debating on whether to post this or not since it doesn't seem to make much reliable sense to me, but for the sake of being openminded, I'll tell the story anyway.
A few months ago I was was having alot of trouble with the the hard-drives not getting detected. It would happen on and off until one week when it never seemed to come up at all. Something was getting worse - most likely the IDE cables that everyone talks about. So I took it apart to fix it.
I tried recrimping the cable - no luck
I swtched the drives - still no luck.
I switched the ends of the cable around - having it use the other side of the cable on the motherboard - no luck
At this point - it was never coming up - I was sure that I had hosed it royally - so I started trying stuff that had no rhyme or reason to it.
The last thing I tried was re-pluging the drives and rebooting about 6-7 times in a row and each time the empeg did not recognize the drives.
Then... (and here is the pre-kicker):
I plugged the ide cable (on the motherboard side) in backwards (meaning plug0 was not plugged into pin0) - and as expected, no drives detected.
Now for the kicker:
When replugged the ide cable (on the motherboard side) in correctly, it worked. I was amazed!
I checked the board for cold solder joints and they all looked OK - plugged it in again and it still worked!
I've been using it for months now (same as before) and not once have I had an IDE problem. The drives have been detected every boot - which is more than daily.
I'd like to hear what the more technical gurus have to say about this one - because it is certainly contrary to my intuition on how this stuff works. I suspect that it had something to do with turnng the empeg on with the IDE cable on bcakwards. Either that or it is just FM!
Any ideas?
Brent
RioCar MK][a 20GB+80GB
'96 Saab 900s (Not any more)
Still looking for a good way to install in a 2010 BMW 3 series with iDrive/NAV
