Tony, how does this plugin work?
First, put it in the main plugins directory (not under hardware or software.) To use it, you need to go to File/Settings then to the Plugins tab and put a check mark next to "Advanced Mouse Event." Then create a command and in the box in the lower right hand corner where you define the action for the command, go to "Plugins" and a list of your plugins is there.. Select "Advanced Mouse Event." Then if you click "Settings" you'll have a window with all the options for what the plugin can do (click, double click, move & click, etc.) The main thing I use this for that the regular Mouse functions don't give is the ability to do "mouse button down" then "mouse move" then "mouse button up" which lets you drag windows around. I don't use it often in the manual sense, but as part of macros where I wanna position windows or move things around automatically, it works very well.
