Also, there are different settings for compression. But, the default is the best trade off between speed and compression. If you're willing to wait longer for the file to encode, of course you can change the setting. But my understanding is that higher compression ratios (above the default) slow down the encoding considerably. In the third table on this comparison page, you can see the difference between a few different flac settings in terms of compression / encoding time.
