Perhaps what's really required is a third mode for searching: append after current track (rather than add at end of playlist, or replace playlist)...
This is planned, but there are UI issues to be addressed. The current mechanism for switching between select and append is incredibly confusing and limited in scope. We need a global setting that affects playlist selection from the main menu too so you can select a playlist for append, insert or replace.
Actually implementing it isn't hard at all.
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
