Ok...I feel like the dumbest man on the forum!!!
I plugged the IDE Cable into only have of the pins. Well, I have fixed that and it is fully seated now. But, I am getting the No hard disk found...contact support error again. I have flashed it with Hijack 361 (not the customized one) because it was giving that error.
It is still giving that error even after the reflash.
Here is the hyperterminal output:
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=c7)
empeg audio-in initialised, CS4231A revision c7
empeg usb initialised, PDIUSBD12 id dfdf
empeg-car bootstrap v1.02 20001106 ([email protected])
If there is anyone present who wants to upgrade the flash, let them sp
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v361 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sun Jan 25 22:34:59 EST 2004
empeg-car player (hardware revision 9, serial number
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 16384 bhas
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9b790
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x0049
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
