You could use SOX to convert WAV to PCM. But if it's already 44.1khz 16bit stereo WAVs, then you can just take out (I think) the first 64 bytes. For the most part, stripping the WAV header (whatever it is) is the same as a PCM (to my knowledge), as long as the base parameters (sampling rate, channels, etc.) are the same.
