I recently picked up this Firewire/USB 2 PCI card and this front planel connector, with the intent of them both working together.
The wiring for the front panel is all loose to enable it to work with almost any motherboard header, unfortunetly the header on the PCI card is completly unlabeled - though I was able to figure out which was the USB header and which was the Firewire header.
Is there any way to figure out what the pin assingment is?
Upon reflection I probably should have picked up this setup.
