You meen crazymelki, instead of Thomas?
ok..Maybe I will get a free upgrade as the first power tester ;-)
Strange I got right now two different errors..Here the first one. In the meantime I am trying to reproduce the other one.
empeg-car bootstrap v1.00 20000601 ([email protected]) CHS=19485/16/63
On DC power, quick boot
e
Partition check:
e000 v1.04
empeg-fl
Copying kernel...ized3] hda1
Calling linux kernel...
smc chip id/rev
smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])0 blocks [1 disk] into
l.m
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v388 (root@ibbm) (gcc version 2.95
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP M
.3 20010315 (release)) #2 Thu May 6 12:52:42 EDT 2004ded
Processor: Intel StrongARM-1100 revision
e
Dentry hash table entries: 2048 (order 2, 16k)rfs but got error 19
Buffer cache hash table entries: 16384 (order 4, 64k)on irq 6
Mounting s
hda: TOSHIBA MK1016GAP, 9590MB
POSIX conformance testing by UNIFIX4 but got error 6
Linux NET4.0 for Linux 2.2r mounting partitions (pos
pla
TCP: Hash tables configured (ehash 16384 bhash 16384)eg-car 3.00-alpha7 2004/02/13. Loading 320 blocks [1
Starting kswapd v 1.5
hdstress.cpp 189 ( 14):
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTg-car bootstrap v1.00 20000601 ([email protected])c
If there is anyone present w
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART,
Signature is 20706d65 'emp '
VFS: Mounted root (ext2
Found custom animation at offset 0
empeg dsp initialised
empeg audio-in initialised, CS4231A revision a0rved for the super user
empeg remote control/panel button initialised.-1100 revision 11s.cpp 189 ( 14): Poll re
NetWinder
empeg state support initialised 0089/88c1 (save to d0004d80).
empeg RDS driver initialisedg=0)
empeg power-pic driver initialised (first boot)serial number 80000558)upsdev/hda: Spinning
8192 bl
Command line: mem=1
empeg single channel IDE
smc chip id/revision 0x3349
TCP: Hash ta
hdstr
hdstr
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:02:2
hdst
Drive
e6
Partition check:T
hda: hda1 < hda5 hda6 > hda2 hda3 hda4ss.cp
VFS: Mounted root (ext2 filesystem) readonly.
empeg display initialised.
Freeing unused kernel memory: 4k init
empeg dsp audio
Probing primary interface...0
r10: 00000005 r9 : 00000000 r8 : 00330003A DISK drive9): Poll result=0 on fd=5
r7 : c0ffdfc0 r6 : c0159740 r5 : c0ffd040 r4 : c0ffdd3cda: TOSHIBA MK1016GAP, ATA DISK driveeed checking /dev/hda
r3 : 0000007c r2 : 00000000 r1 : c0157fa0 r0 : 00000009
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment kerneless.cpp 189 ( 29): Po
St
Control: C000517D Table: C000517D DAC: 0000001D
Stressi
a8t.
c0003b80: c0003b8c c002ab20 c002a358 00000000 c0103fb8 00000000 00000400 c0003besent who wants to upgr
SMC9194: SM
c4C9
c0003ba0: c0003bac c0033ed4 c002a900 c015bf60 00000000 00000000 c0003bfc c0003b
hdstress.cpp 1
c8(
c0003bc0: c0033f9c c0033e68 c0ffe000 c0002000 00000000 00000000 c0ffe000 000004
hda: [PTBL] [1222/255/63] hda1 < hda5 hda6 > hda2 hda3 hda4 Penguins of Linux!
00
c0003be0: 00000305 c0103f78 c0103f18 00002105
Mounting second music partition8)ress.cpp 189
ec
c0003c80: 00000008 00000000 c0003cd0 c0003c98 c004adcc c004a874 c0003cec c00155ount /dev/hdc4 but got error 6
Error mou
ccng
c0003ca0: 00000000 00000010 c0003d10 00000000 c01879c8 00000000 c01879c8 c01007
hdstress.c
Linux N
g player Lin
982
08
c0003d00: c0185060 c01852e0 c0003d2c c0003d18 00000000 00000000 00000000 000000pinning up.p.t=0 on fd=
00
c0003d20: 00000000 00000000 00000000 00000000 00000000 c0185360 c01879c8 c01879lash, let them speak now,TCP
c8
c0003d40: c0003da4 c0100798 00000001 c0003d78 c0003d5c c004c12c c004bdd0 000000
or forever hold their peace...it seems not.
00t
c0003d60: c0185360 fffffff4 c01852e0 c0003da0 c0003d7c c003ac24 c004c0fc c0003d
a4
00
c0003de0: c0003e8c c0100770 00000001 c0100798 00000000 c0003f6c c0003e04 c0039b8 Corel Computer Corp.
c4
c0003e00: c003b050 c0003e38 c0003f98 c004265c c00155cc 00000000 c01fda00 000000 (hardware revision 7, serial number 80000558)
30
c0003e20: c01176c8 c0003ea4 00000001 c0003e58 c0003e3c c0042820 c0042598 c0003e
empe
Calibrating delay loop... 207.67 B
6c
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 0
649:
c0003e80: 4401a11b 00000000 c0003ec0 00000000 00000000 00000000 00000000 000000
Based upon Swanse
eU
Part
Starting kswapd v 1.5NE
000
c0003ea0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 000000ns enabledda2 hda3 hda4
00
c0003ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 000000
empeg-
00 S
c0003ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 000000irq = 16) is a SA1100 UARTd root has d_count=1
00
c0003f40: c0100798 c0008000 c0008000 c0100770 c0100798 c0003f98 4401a11b c00085driver initialized: 16 RAM disks of 4096K size92 blockstialised (first boot)
c0
c0003f60: c0003f90 c0003f70 c000eef0 c0039b64 c0100798 c000a248 0000000b c00020peg single channel IDE blocks (0.00%) reserved
00
c0003f80: c0003fd4 00000000 c0003f94 c000a0a0 c000eec0 c0100798 c00e730c c01007C25N080ATMR04-0, ATA DISK drive disk dr
70
c0003fa0: c0100798 c00e730c c0100798 c0100770 c0100798 c0100770 c0100988 4401a1
Block size=1024 (log=
hdb: I
1bN0
94
Backtrace:
RAMDIS
Function entered at [<c002a34c>] from [<c002ab20>]
RAMDISK: Loading 320 blo
r10 = 00000000 r9 = C0103F18 r8 = C0003BCC r7 = 00000005
r6 = 00000000 r5 = C0159748 r4 = C0159740
empeg-pump v0.03 (19980601)
Function entered at [<c002a8f4>] from [<c0033ed4>]
r7 = 00000400 r6 = 00000000 r5 = C0103FB8 r4 = 00000000
Function entered at [<c0033e5c>] from [<c0033f9c>]
Function entered at [<c004a868>] from [<c004adcc>]p v1.00 20000601 ([email protected])
r10 = 00000000 r9 = 00000008 r8 = C0003CEC r7 = 00000000
e000 v1.04
r10 = 00000006 r9 = C0100798 r8 = C01879C8 r7 = 00000000
r6 = C01879C8 r5 = 00000000 r4 = C0003D10
Function entered at [<c004bdc4>] from [<c004c12c>]
r10 = 00000001 r9 = C0100798 r8 = C0003DA4 r7 = C01879C8
r6 = C01879C8 r5 = C0185360 r4 = 00000000
Function entered at [<c004c0f0>] from [<c003ac24>]
r6 = C01852E0 r5 = FFFFFFF4 r4 = C0185360
Function entered at [<c003ab98>] from [<c003af10>]
r10 = 00000001 r8 = C000800C r7 = C01852E0 r6 = 00000001
r5 = 00000000 r4 = C0003DA4
Function entered at [<c003ad9c>] from [<c003b0a4>]
r10 = 00000000 r8 = 00008000 r7 = C0100770 r6 = 00000000
r5 = C0008000 r4 = 00000000
Function entered at [<c003b044>] from [<c0039bc4>]
r10 = 00000000 r9 = C0100798 r8 = 00000001 r7 = C0100770
r6 = C0003E8C r5 = C0008000 r4 = C0008000
Function entered at [<c0039b58>] from [<c000eef0>]
r10 = C00085C0 r9 = 4401A11B r8 = C0003F98 r7 = C0100798
r6 = C0100770 r5 = C0008000 r4 = C0008000
Function entered at [<c000eeb4>] from [<c000a0a0>]
r8 = C0003FD4 r7 = C0002000 r6 = 0000000B r5 = C000A248
r4 = C0100798
Code: e3520000 1a00000b (e5884000) e2844004 ea00000a
crazymelki.com
