These folks expressed interest also. I've sent a follow-up.
-----Original Message-----
Sent: Wednesday, June 23, 2004 4:03 PM
To: Alvin Barber
Subject: Re: Quotation for a short run casting
Hello,!
Go ahead and send pics and as much info as to qty and colors and especially info on you . if your are a private company or an individual looking for a one time short run. Best regards, JOE HINOJOSA
Sent: Wednesday, June 23, 2004 1:53 PM
To: Alvin Barber
Hello Alvin,
This does sound like something we can do. The transparent colors do cost a
bit more, And this is all cast by hand so it does take a little time to
make a run. mostly we are limited to 2 casts per day per mold. We can make
more molds if the run is needed in a specific time frame.
The molds will have a cost for material, which these sound small so it
should be pretty reasonable, and time to make.
then we will have a per piece based on your total run, I can get you an
estimate per piece it you can give me the dimension and possiably a pic of
the pieces showing me front and back , and hopefully a side,
We also can do black light sensitive pigments that "glow" a blueish white,
also we do pearl colors.....we can sample those to you when needed. THANKS tony
