Okay, this is a pie-in-the-sky idea. But here goes...
It occurs to me that the Hijack kernel for the car player, with its streaming audio web server, is about 75 percent of the way towards being a server for the Rio Receiver already.
All it would need to do is:
1) Respond to commands from the Receiver on the proper port, and format its web-interface output in the way that the Rio Receiver expects to see it. Which is really not that different from how it outputs the queries from web browsers right now.
2) Be able to hand over the .ARF file when the receiver asks for it. Easy, just have the end-user drop it on the car player's hard disk (have them put it in EMPEG/VAR please so that we don't need to reinstall it each time the player is upgraded).
3) Be able to respond to the boot-up broadcast message the receiver sends and then feed the receiver an address. This might be the hard one, as I don't know if there's any lightweight DHCP code that would fit in the kernel. Then again, maybe if you implemented a simplified subset (limit the number of served receivers and put hard-coded addresses for them in the config.ini) then it wouldn't be a big issue?
Mark, have you thought about this before, already?
