Well, I finally got my Rio Central! I ordered it on Febuary 7th, received it on March 29th
It arrives on my doorstep with the free Rio Reciever. Unpacking, I'm very happy with the packaging and out-of-box experience.
Plug them in and they work like a charm. Ripped a new disk in about 8 min, while playing the first two tracks. Nice! Sound quality is superb, and the machine is a breeze to use. I like the games too Definitely pick up a USB keyboard, it's worth it (press Ctl-Alt-Del for a unix prompt).
Got a USB->Ethernet adapter (LinkSys 100M) which was not compatable. Returned it for another (LinkSys 100TX) which works fine.
Network setup was a snap, pinging worked, and 'search for update' worked (no update available yet). But could not contact the device with Emplode. After reading the boards, I learned that it has to be enabled in the 'emplode password' menu.
Start up emplode, drag 200+ CDs into the window and press 'sync'. Go to bed.
Wake up: Sync failed due to lost connection (or some such).
Now, I'm stuck with this problem, and emplode can't download the database from the player either (gives same error). I've tried power-cycling. The Central has no problem viewing it's database, and I can play/surf the files with no problem, but emplode cannot access it.
Any clue?
EDIT: Moved bug to bug forum..
Edited by brturn (03/04/2002 13:59)
