OK - found the scanner, which actually works in a directory of m3u files which point to shoutcast servers - BUT -
-0.2.3\etc\jreceiver.properties
[WARN] ScannerDaemon - -parsing-problem with [alternative.m3u] reason: io-proble
m reading playlist file, java.io.IOException: Failed to open HTTP connection
...it seems to give up on the entire playlist if one item in there can't be accessed?
-mark
http://mvgals.net - clublife, revisited.
