I just got a rio and hooked it up using arm 1.4 w/o any problems. I then installed a fresh copy of trio 0.1.4.alpha5. The receiver finds the trio server fine. When I run the java web client I have a problem. I can add shoutcast stations fine and they play well. However, when I select Queue 'n Play and then try to add songs through "artist" nothing happens. At first I thought I had the wrong IP in trio.xml, but I'm pretty sure that is correct now, yet it still happens. BTW, I'm running Win2K as the server.
Any pointers would be great as I really want to use trio!!!
Thanks.
